The system-packages-doc interface
The system-packages-doc interface permits access file system locations used to store system documentation. These include the following
  • /usr/{,local/}share/doc/
  • /usr/share/cups/doc-root/
  • /usr/share/gimp/2.0/help/
  • /usr/share/gtk-doc/
  • /usr/share/javascript/
  • /usr/share/libreoffice/help/
  • /usr/share/sphinx_rtd_theme/
  • /usr/share/xubuntu-docs/
After the interface has been connected, the host’s /usr/share/doc directory replaces the /usr/share/doc for the context of the snap.
This interface is helpful for web browsers, for example, because it enables them to open and view the host’s HTML system documentation.
Developer details
Auto-connect: no
The interface it is not connected automatically because the listed documentation can be used to infer which packages are installed on the host system.
Code examples
The test code can be found in the snapd repository:
snapd/interfaces/builtin/system_packages_doc_test.go at master · canonical/snapd · GitHub
The source code for the interface is in the snapd repository:
https://github.com/snapcore/snapd/blob/master/interfaces/builtin/system_packages_doc.go
Last updated 5 months ago.
